Another estate car arrives
- Citroen Sorceror
In this case a pale blue TGD with four odd but legal boots, 93000 miles (We found the evidence of a replacement speedo at 50,000) an engine that runs a bit, after some tinkering. The timing is probably out, I reckon and the Blaupunkt is good. Better still, it has had a Kenlowe fan fitted which a mate with a Landy covets and will pay me £25 for, I'm sure. Cost? £14 once carpet money is taken into account so I'm in profit already! Until the vintner's bill comes in. DLM was much traumatised by 40 miles on solid tow and is busy dealing with a bottle of red...
- Citroen Sorceror
- Citroen Sorceror
- Keeper of the site Goat
- Our Trim Guru
2020s - A shinier red TZD estate has replaced scruffy 19TXD "Red Shed". - x 10
Now I know how Schumi feels when he's slap behind the next back-marker and about to overtake - except that overtaking's not an option when there's about 5 feet of solid towbar firmly connected between you and the car in front, and you're equipped with an engine that won't run for more than 30 seconds without dying....DLM was much traumatised by 40 miles on solid tow and is busy dealing with a bottle of red...
- Citroen Sorceror
I'm feeling both happy and a little foolish. I had stated categorically that the engine was well stuffed. I had turned it over and it spun over so fast that I reckoned it had no compression; thinks: cracked head and blown hg between two pots. Trouble was, once I'd bought the car and whipped the plenum off, the car could be gotten to run, albeit very weakly so I wondered about a timing issue. It wasn't that. It was the primer pump's non return valve going all Happy Birthday. I bypassed the filter unit and the engine started first turn. It kept running, too. Just lucky, I guess
