Questionaire about BXs in uk
Hi,
I am realy curisous about some thing about BX in you country. If you find this topic stupid, delete it
Can I aks you for some questions? Of course if you will
Do you use this Total HYDRAURINCAGE?
Do you prefer new spheres or just refurbished spheres?
Why your bxs don't have the the upper case- http://www.bxclub.cz/graphics/dynamic/1715554_7.jpg we have it on the left side
Do you have any problems with clutch kable? It must be tweaks because of you're sitting on the other side
and it's almost imposible to get electric right mirror (letf is really often in BX), do you have it, or it's just manual?
And in 16v: rider's seat - you can change position of the whatyoucallit on your hips, do you have it too?
And I was very surprised, that in France 16 soupapes hasn't back electrik windows, it's the same in your country?
I am going to shup up for a while
Yes I've used Hydraurincage
No opinion on spheres - I put new ones on mine.
Don't know about graphics - probably a cost-saving measure from Citroen
I have electic left mirror and manual right. I suppose you could fit a left-hand mirror upside-down on the right side....
Don't know about 16v driver's seat
My TZD has electric rear windows, which don't work
I meant to say
I don't find the topic stupid at all, and I doubt whether anyone else will. I'm very impressed at Cz BX club's turnout and enthusiasm, and we could probably learn from you. I like your idea of a mutual breakdown help scheme, for instance. I think we could copy that.
In cz is the shortcut RVHP and it's parody for economy council from "old and red" ages we let the whole name, just the letter "H" means hydraulics. In english it's not funny nameOscar wrote: I like your idea of a mutual breakdown help scheme, for instance. I think we could copy that.
But it's realy helpful
We have big discussion about spheres, I prefer new, and many people prefer the re-fill, because it's cheaper (and they say it's good as new).
that's the same problem as using LHM or normal hydraulic oil? Sometimes people do strange things, when they want to spend some money
Sorry, can I just say here and now... climate control?! in a BX?! I never knew that was available! And a little exterior temp sensor in the clock - that's rather nifty too!
In answer to your questionnaire:
Never heard of Hydraurincage but I assume it's the same as Hydraflush, which I would use?
I'd buy new spheres personally, if I could find and afford them.
Re. the upper glovebox, I assume as Oscar says it was a cost-cutting measure
Don't know about the clutch cable.
I seem to remember my TZD having electric mirrors on both sides when I had it. But my ZX used to only have an electric mirror on the left-hand side, for some reason - the right-hand mirror was manual. Odd.
Yes, it is possible to change the grip on the side bolsters of the 16v driver's seat over here.
TZD's have electric rear windows so I assume that 16v's do too.
Sorry, I've probably not been much help. I'm still in awe of the digital climate control!
1984 Black Ford Capri 2.8 Injection (Specialised Engines Stage II) - Pride & Joy
1996 Hermes Red Citroen Xantia TD SX Estate - Autoroute Cruiser
that's my job.. the digi clima and the clock are from XM too.
But I choose bad black collor, co the panel of digi glima is other
XM
cables to clima from XM
than instalation
that was funny
putting airbox back (with servos)
my legs and original panel from XM
modifying old panel
[/img]
afer first layer of collor
And I am going to kill everyone who will copy me and my digi clima
XM
than instalation
that was funny
modifying old panel
[/img]
- docchevron
Re: Questionaire about BXs in uk
Hi and welcome Darja! Great to have you "on board"
Yep, good stuff!
I nearly always fit new, unless the sphere is a genuine unit in which case they usually re-charge well. If it's an AMTEX sphere I just throw them in the bin
Economics or because we are british I suppose!!!???
Clutch cables can break but I dont think it afflicts BX's anymore than other cars. The pedal box design is rubbish but the box is no different ona LHD car so it's the same for us all!
Over here the drivers mirror was nearly always manual, except as an optional extra or standard in the case of the P2 16V. passenger mirrors were options on most BX's and standard on higher trim spec cars
You can adjust the lumber support and the "wings" that grip your ribs, the base will also tilt but I've never seen one that adjusts on your legs over here??
Blimey, for once the english got better spec than the french!? All 16v's had electric windows all round over here, and TZD's too!
Chris G
Yep, good stuff!
Chris G
- docchevron
Stunning job with the climate control! I'm a little envious....
Thought the controller panel looked XMish. hhmm, I'm fitting Air-con in the BX soon, maybe climate control too.....
Perhaps I should fix the suspension first!!!
Stunning work fella!
Chris G
Chris G
I was surprised, because 16v is imaginary TOP of BX, so every 16v in CZ (at most they came from DE) has rear el. windows. French 16s is like social
I had 1.6 TOP and I have just front el. windows and one mirror, but I thing that all GT and GTi have all windows in el. And TD ( I know a few TD,and everyone is in el.)
Jop, it's better to have BX in perfect shape, than make this things... that remember me I need new brakes.. have anyone put bigger brakes on 16v? f.e. from Xantia?docchevron1472 wrote:Stunning job with the climate control! I'm a little envious....
Chris G
- docchevron
I think it's safe to assume that neither of my cars will ever be in perfect shape Darja!!
Why do you want to put bigger brakes on the car mate?
The 16v setup is very good standard.
Think you'd struggle to use Xanty brake calipers..
Chris G
hmmm, for the future they'll not strong enought , they're good now (all bx brakes are great), but more HP, needs better brakes...docchevron1472 wrote:
Chris G
And (if I forget the practical reason), it looks better (bigger brakes) at 15"
I just ask, if someone has experience...
I have one question: why is everyone crazy about 16v? What's special on it?
- Terry Brooks
- Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
Hi...........My '92 TZD Saloon
1. No .....all I've ever put in my BX is LHM
2. Refurbished
3. Dunno
4. Not had any probs with the clutch cable yet,I hear it's a tricky job to fit a new one though.
5. Electric left,Manual right mirrors on my BX.
6. Yes,I've got BX 16v seats in my 2CV,and there's an extra adjuster on the drivers seat only which is'nt on the seats in my TZD.
7. Yes, my TZD has an electric heated rear window,and yes,it does work.
Errrr .......not much help ......am I
Terry
'92 BXTZD
'88 2CV Special
2. Refurbished
3. Dunno
Terry
'92 BXTZD
'88 2CV Special
- docchevron
I think you'd need some epic HP increase and indeed top speed increase to require bigger brakes but....
I use EBC racing pads, never scared myself yet!
Duno why everyone else loves valvers so much but I like them because I think the bodykit looks awesome, the noise they make is awesome, and they can embarress a lot of punks in modern "go fast" very expensive cars.
Theres something very addictive about them.
Chris G
Chris G
Hmmm awesome.. I don't think so, BX is smiling cardocchevron1472 wrote: Duno why everyone else loves valvers so much but I like them because I think the bodykit looks awesome, the noise they make is awesome, and they can embarress a lot of punks in modern "go fast" very expensive cars.
Not some wouldbe sportscar
and the bodykit... you can put it on every BX I'm selling it for 100EUR
If my dear want not put it on his GTi (only 8 valves )
