hurricane for sale
donna
hurricane for sale
bx tzd turbo hurricane for sale ive broken the gearbox and carnt be botherd with it anymore good engine and the interior is green/black its like new no rips or marks body work is solid but has scratches it still has short tax and mot gearbox has been removed £80 telford area 01952 594566 ps. it has a diffrent colour o/s/r door thanks gaz
capri
capri
- Keeper of the site Goat
donna
hurricane
it will go on the back of a trailler with no probs you dont need a hi ab with the drive shaft tied up safe it will be fine i will put the track rod end back on bottom ball joint and road wheel regards gaz
- BX Digit man!
But.... what will you do about the engine hanging out? Given that the engine is mounted through the gearbox, without one fitted, the car is immobile.
I suppose you could fit a piece of box-section between the inner wings, and tie the engine up, but I wouldn't want to move the car like that.
donna
hurricane gearbox
ive used 3mill wire rope tide to the gearbox housing holes with bulldog clips to the top inner wings mount
adamskibx
I may have a TD gearbox that I thought I was going to need in the GT ages ago, but I didnt use it in the end as the clutch was the thing making the odd sounds. I know ive got two gearboxes, and when my brother was helping me carry them round the back of my house, he dropped one
I cant remember whether it was the TD one or the 1.9 carb one, but will have a look later. Also, Telford is not too far from me (I think
) I work in Droitwich. If the gearbox is OK, then im quite happy to give someone a hand popping it in the car, perhaps with a new clutch..
