2 Interesting BXs on ebay.
Two interesting BX's but for very different reasons.
http://cgi.ebay.co.uk/1986-CITROEN-BX-1 ... dZViewItem
http://cgi.ebay.co.uk/CLASSIC-CITROEN-B ... dZViewItem
Daniel B
spigven
stuart_hedges
stuart_hedges
Very kind of you!
I'm hoping to go and have a look at it this weekend - I've emailed the seller and am awaiting a reply. I've had Gs and a CX before so I know the hydraulic tests, but are there any particular problem areas I should look out for on a BX? Or perhaps there's a buying guide posted on the net somewhere?
As for lightbulbs... it was easy on my GS which is lucky because it had a voltage problem and used to blow them quite regularly. I never dared on my GSAs though because you have to disconnect the speedo to do it...
M
Have asearch through the BXClubs main site - Tom covers teh subject quite well.stuart_hedges wrote:. I've had Gs and a CX before so I know the hydraulic tests, but are there any particular problem areas I should look out for on a BX? Or perhaps there's a buying guide posted on the net somewhere...
Rust, rusty pipes, electrical gremelins (faulty earthing), rear radius arms, ball joints, HP pumps, spheres being flat and so on.
citroenxm
Yes. Look for rot in the boot, open the hatch, tap the back of the boot, LIGHTS end all the way across, they temd to go on the cross member chassis area, if you have to lift the carpet up. . As useual check the rear arms, stand a few meters back behind the car and see for any leaning in.
The rest of the car is pretty much "normal" for bulb changing etc etc.
Good luck.
Good luck.
- Keeper of the site Goat
Door bottoms from the inside of the car for holes/rust, put suspension in high setting then lower all the way down whilst checking for any creaks, smoothness of operation and then outside to check for any LHM leaks. Also (though blindingly obvious except to me!) check screen for cracks and stars.
Vauxhall apologist.
spigven
AlanS
This is where anyone interested in buying a BX should start.
http://www.tramontana.co.hu/citroen/maint/maint.html
Alan S
Alan S
stuart_hedges
stuart_hedges
Well, I had a look at the red Mk 1 on Saturday. I will be bidding, but not too high. It seemed mechanically strong - it hadn't been used for a while but started first time and rose up fast and smooth on the suspension with no creaks or groans. The pump clicked about every 8 seconds, which is mildly worrying, but the power steering worked fine. Clutch, gearbox and engine all seemed fine.
The seller was pretty vague (I think just because he was, not because he was being difficult) but as far as I could see the "hydraulics all done" in the ad means four new spheres.
Electrics were all ok except for the central locking, which only worked from the passenger door. Any idea if that's an easy fix?
Also one window didn't seem to be in its runner properly, went up wonky and needed a helping hand to shut properly.
Rust up one of the A-pillars and on the shell on the rear wheelarches, visible when you open the rear doors. It was on the surface but taking a good hold; possibly still within the reach of Jenolite but might require welding.
Boot floor was good, but the bloke was a plasterer so very dusty in there!
Driver's seat torn and front headrests missing. Dash a bit faded.
Worth a punt, I reckon. But not too much. I'll bid maybe a hundred and not be too upset if I don't get it.
stuart_hedges
