where to buy new battery terminals
cacaolat
because of the trouble ...see below "Meteor 16 TGS starting issues" I will buy some new battery terminals. Any advice on a good place to buy them, and how long is it going to take to fit them..?
Stewart (oily!)
You can buy loose terminals which screw on to the existing lead or a complete lead with terminal attached.
You can even pay as much as £9.99 for posh ones
http://www.maplin.co.uk/Module.aspx?Tab ... 6&doy=20m3
cacaolat
the suggestion ...cutting out a bit of the old lead connector sounds good...not that I want to spend any money, but I like recycling and keeping things in their original state....I will try that cheers
- x 94
- x 94
cacaolat
Thank you for the advice. I have cleaned the old terminals woth wire wool and cut out the bit with the hacksaw... The electric starting issue seems resolved. Unfortunately the other starting issue seems to have kicked in now ? (I stalled the car last night after the first 5metres and it would not start again.... I will try again in about 20 minutes.Stewart (oily!) wrote:Any motor accessory shop, caravan places too, iif you remove the bolt from your standard clamps and cut a thin slice out of the "slot" using a hacksaw, then place a few washers under the nut on reassembly they can go on working.
Stewart
Doz
Sounds like the old auto choke flooding issue .... mine still does it from time to time... If you do stall it , when you start it back up , hold your foot to the floor whilst turning the engine over. Don't pump the throttle at all.... you need to dilute that neat mixture! Doing this mine always manages to chough and splutter unto running again ...
Anyone got a solex manual choke kit? *or even a place to buy one?
Doz
2007 Citroen C1 (it's not a real Citroen)(With a complete set of wheel trims)
2006 C4 1.6VTR+ (Alloys no wheel trims)
1982 Mini HL (No wheel trims, no wheels)
1993 Kawasaki GPZ500
ellevie
- Forum Treasurer
http://bxclub.co.uk/forum/viewtopic.php?t=1525Doz wrote:Anyone got a solex manual choke kit? *or even a place to buy one?
The website is defunct but it might be worth giving the number a ring.
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
BX19TXD 150k K Reg
