Citroen Special Tools
sleepy0905
Post by sleepy0905 »
Does anyone know where to buy the citroen special tools or are they just a myth for the main agents?
Our Trim Guru
x 10
Post by DLM »
They certainly existed, and some VERY occasionally come up on ebay and such like. It's often the case that a bit of lateral thinking, copying or just straightforward common sense can lead you to alternatives. For example, refitting the lever on a front caliper is a job where a special Citroen tool is advised to compress the spring washers underneath it, but the job can be improvised with basic tools and a vice.
x 103
was it specifically BX ones you where after? i have some berlingo ones i could do with off loading! Like DLM said they come up on ebay from time to time and thats where i got mine from :D
sleepy0905
citroen ones are fine as they fit most of there ranges but how much are you looking for the belingo ones as cash is very strapped.
Grace
Post by Grace »
What in particular are you looking for?
sleepy0905
most i have managed without but the tool for removing the axial joints 8.0707-T would be usefull rether than having to use stilsons. :D
tom
Citroen Sorceror
x 38
Post by tom »
And the balljoint removing tool?
sleepy0905
I have the balljoint tool it only cost me about £6 :lol:
tom
Citroen Sorceror
x 38
Post by tom »
I mean the device for removing the lower balljoint from the hub carrier. Do you?
sleepy0905
you meen the funny socket. see below it cost me £4.58 exc VAT. you also need a 35mm socket to use it.
:D
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
sleepy0905 wrote:you meen the funny socket. see below it cost me £4.58 exc VAT. you also need a 35mm socket to use it.
:D
Where from?
1991 Landrover Discovery
1995 VW Golf SE
sleepy0905
Portland Tool and Motor Factors 46 portland street Lincoln tel 01522 542802 / 538132
This is where I get most of my Tools and they are not badly priced. :)
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
Cheers! =D>
1995 VW Golf SE
tom
Citroen Sorceror
x 38
Post by tom »
THANK YOU VERY MUCH, SIR!!!
x 103
either Facom or Sealey have it on there website and its about that much delivered! I was very kindly lent one by a Andyspares member last time i did it and it makes the job dead easy. The one i changed was very badly corroded but i did as i was advised and basically set fire to the ball joint untill it started to bubble, then gave it a few minutes and put the tool on with a breaker bar. It came straight off without breaking a sweat, very impressive!
