1984 19rd
Martyn
1984 19rd
I have acquired the car which has been resprayed dark blue and apparently looks good(I have yet to pick it up). As I live on Loch lomond I realise it is a long way for most, but I require the exhaust and little else. Please pm me if there is anything you want, pref. with landline number. All I want is to get rid with minimal expense, doors are off it as is trim(light blue). Good runner, new pump etc., I lack energy and skills to put it together. Open to suggestions. Martyn
1992 txd
1991 1.7 tzd
1991 1.7 tzd
- BX Digit man!
Before you break a 1984 diesel....
Do you know which month the car was registered? 1984 was the first year that a BX diesel was available, so there's a risk you may be breaking the earliest BX diesel left in the UK..... please don't do that! I felt bad enough breaking and scrapping a 1985 17rd recently.
If you're in need of a 1.9D exhaust, I have one here you're welcome to. That said.... I am the opposite end of the country to you, so it may be of little value.
If the car is basically solid (which the 17rd I broke wasn't!) then it must be worth saving...
- BXpat
stuart_hedges
Martyn
Just got logbook- car registered 30/01/85 B reg. Interior blue. I still haven't seen it but I believe it is mint bodily, sprayed dark blue with light metallic speckle (seen one panel - looks nice) Under a great deal of uxorial pressure not to bring it home (or very briefly). over to you!
1992 txd
1991 1.7 tzd
1991 1.7 tzd
tom
- Citroen Sorceror
tom
- Citroen Sorceror
artic-steel
tim leech
Martyn
Owner is champing at bit to get car removed from third party's farm. I can only give you chassis number - VF7XBXC0010XC4146. iI hope this helps. Reg no is B541 HRM. Good engine(thet I was going to remove) new pipes, spheres etc. I would rather it went to a good home. Exhaust is for my 92 txd. BTW I have both 1.7td and 1.9d, while the latter is slower, I prefer the slightly lazier power delivery. However a tzd2.1 still remains my fantasy.
1992 txd
1991 1.7 tzd
1991 1.7 tzd
- BX Digit man!
