clunk,click every trip
another one that's not quite technical.. came out of the shop and the hound had chewed through the seat belt thoughtfully leaving two threads so I can close the thing but it's not going to save anyone from anything or satisfy Herr TÜV (MOT) inspector.
I need to know whether all BX seat belts have the same mounting and clip design or if there were variations - anyone know? Just been down the scrapyard and studied a mind-bending variety of designs from other Citroens and Peugeots- one or two could be modified to fit but I'd rather find the proper one. If anyone happens to have a passenger side lying about in black and is coming to the National that would be appreciated. If I have a shunt on the way I'll just use the hound as an airbag.
Otherwise I'll try to contact scrapyards here but it would simplify it if I could ask for a BX seat belt rather than the unlikely chance of there being a Mk.1 available. Cheers!
Surely it wouldnt cost too much to post abroad? better to be safe than save a few quid....
tom
Citroen Sorceror
x 38
Post by tom »
Surely the hound is a doggybag? PM our good friend DLM who is breaking a car. I'm sure he'll be only too glad to help you out.
prm
Clunk Click
Post by prm »
Todd,
This one caught me out with a hurried MOT test, and stalk replacement.
If your changing the belt, check the replacement belt fits your original stalk.
Would recommend a matched pair.
I believe the design has changed several times. They look similar, but fail to lock .
Our Trim Guru
x 13
Post by DLM »
Prm is correct - especially about the non-securing clips and stalks if you try to mix'n'match.
I'm aware of 2 types, but there could be more. The earlier type has an orange plastic insert on the stalk, and the later type a red plastic insert.
Toddao - have replied to your PM.
Thanks everyone, hopefully will be sorted by DLM. Encoded the word 'seatbelt' into the hound's mind by waving the broken thing in his direction - sends him scurrying into the corner maybe should add 'head-rest' and other items. Once bought a cheap van that was a true 'dog-box' - everything that could be chewed had been. The seats had been chewed down to the frames and I sat on a pile of cushions from garden chairs instead. Good engine though - Datsun 1200 ( derived from the BL A series?) - not so chewy!
