Wanted - BX Seat belts - MOT failure!!
zebedee150
My BX estate has just failed it's mot and one surprising item is that two of the rear seat belt buckles have parted company from the metal brackets which bolt to the floor pan. I think some chemical has been spilt in the back because the stitching on the rear seat back rest is also coming apart. If any body has a spare black TZD rear seat I up for that as well!
The seat belts I need are the two short webbing ones with the later style buckles (1990 onwards?). Can anybody help?!! Thanks
Bx'less after 12 years
stuart_hedges
Sorry to sound the pessimist but I'd start to worry a bit if I were you!
This doesn't sound like the kind of damage that's localised to one MoT/one fix.
I'd pull out as much trim as you can and have a long, hard look at the metalwork under there if I were you.
French seats from the 80s and 90s are not known for their hard wearing qualities so the stitching is not a surprise. In conjunction with a clear rust problem, I'd be going in there with my Paranoia Hat on though. Sorry
stuart_hedges
- BX Digit man!
mnde
- Meteor Man
Stu you haven't been on the old amberstuart_hedges wrote:I didn't mean to sounds a death knell..... there are guys here who've done some very improbable things.
Juuuust.... broken seat mounts.... split seats... split welds.... sounds like there are beter BXs out thtere.
sorry
Mark.
stuart_hedges
zebedee150
classic2cv
zebedee150
bx seat belts
Hi there. No. unfortunately had to buy some from a guy off ebay. £20 for three rear seat belt buckles. Must value a Bx at about a a grand as a breaker!!
classic2cv
zebedee150
