Hello all I could do with a speedo head for a phase 2 16V if you have one could you kindly let me know please.
Thank you.
Geoff.
speedo wanted.
Geoffrey Gould
- x 116
Geoffrey Gould
speedo wanted.
Thank you Jaba for your offer but as far as I am aware the 8V speedo has different gearing to the 16V one. If anyone knows differently then I would be gratefull if they would spill the beans, as you might say.
Geoff.
Geoff.
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
the 'gearing' si as best i know determined by the gearbox/diff output and after that everything is the same! I've had everything in my current BX (1.9rd, 8v GTi and 16v speedo unit) and they all give exactly the same reading (use my dads picasso to calibrate) so i dont think there is any different accross the range diesel or petrol BE1 or BE3 (the 19rd speedo was for a BE1 gearbox, but worked fine on the BE3 box, though i did swap the speedo and gearbox drive unit at the same time! Actually thinking about it i still have the original BE1 19rd drive unit in the current Xantia gearbox as it originally had an electronic drive unit, hmmm maybe thats the solution to dodgy drive cable, make the damn thing electronic!
Geoffrey Gould
Speedo wanted.
Hello ta I was going by the fact that the number on the face is different on the 16V and I thought the internal gearing would be different as the diff. ratio is different etc. Tried a spare 19 rd one and that was a mile out.
More investigation called for I think.
Thankyou.
Cheers.
Geoff.
Thankyou.
Cheers.
Geoff.
Stewart (oily!)
Geoffrey Gould
Speedo wanted.
Thankyou Stewart will give that a whirl.
Jaba thankyou too, have a number of 8V speedo.
Cheers.
Geoff
PS. Will be still looking for a 16V speedo.
Cheers.
Geoff
bernie
- Likes welding rusty Fiats.
Re: Speedo wanted.
Geoffrey Gould wrote:Thankyou Stewart will give that a whirl.
Cheers.
Geoff
What number is on the front of the speedo?
I have several heads!!!! and one of them is a 16v item
Just the 0 BX
1 TZD Turbo a/c going going GONE
1 TD Hurricane being broken up for spares
3 FIAT 124 Sports!!!
1 FIAT 124 Spider ex. California
Oh and I nearly forgot
A LOVELY XANTIA HDI EXCLUSIVE ESTATE
Geoffrey Gould
Speedo wanted.
Goodevening Bernie Thank you, when it stops raining I will remove the Head and check the number, From memory, which is not too good, all the numbers are the same apart from the last two which are 02. I will confirm asap.
Cheers.
Geoff
Cheers.
Geoff
