BX 16v for sale
csg100
BX 16v for sale
Post by csg100 »
Hey guys/gals,
I'm considering selling my 16v I'm spending too much time and money on it, when I really want to spend my spare cash on the Rover.
It's currently got no tax or MoT and it's leaking LHM from somewhere. Doesn't sound too good, I know, but if someone was interested I could get the leak sorted and hopefully get it through an MoT.
I've done a fair bit of work in the last 14 months on it including 2 front wheel bearings, octopus, plugs, dizzy cap, rotor arm, coolant temp sensor, oil temp sensor, rocker cover gasket, clutch cable, diesel fan switch, idle control valve, inlet mani gaskets a couple of oil/filter changes plus some general tidying.
I've also put in twin cooling fans (although the second isn't wired in yet), a stainless steel scorpion back box and a K&N filter.
Bodywork is a bit tatty - paint is faded. I'm currently refurbing the bumpers though so hopefully they'll come out ok. Looks ok after a polish though.
Engine runs fine though and it certainly goes and stops well.
Jobs that I know need doing for the MoT:
Fix LHM leak
Fix ABS (light stays on)
Other less important jobs:
Fix speedo (lower cable needs replacing)
Could do with a cambelt change as I have not idea when it was last done(I have one ready to go on). last owner said it had had a top end rebuild, but I have no evidence to support this.
Fit new oil temp sensor (I have one, just waiting for the next oil change)
Here's how she looks:
There's a few more pics here:
http://www.carlgibbs.com/gallery/main.php/v/mycars/bx1/
So would anyone be interested? Not sure what to ask for it really, I suppose it depends on how much work I get done on it. but then again I haven't driven it for 7 months, so fixing it and driving it could make we want to keep it! I'm gonna put it up for sale in a few places and will see what happens.
I'd consider some sort of part ex for something sensible with a bit of power and plenty of MoT. I'm currently looking at a T5 Volvo to give you an example.
1990 BX 16v
csg100
Post by csg100 »
The BX now needs to go, so it's on the bay....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0140562332
1990 BX 16v
Keeper of the site Goat
Post by cavmad »
Well worded listing, stands out from the usual numptys advertising cars on there. Good luck with the sale, any gen/pictures on the SD1?
Vauxhall apologist.
csg100
Post by csg100 »
Thanks, took me ages to write that!! :)
This is one of the reasons the BX is going:
There's a bit of info floating around on www.overbore.co.uk about that car and what i've been up to with it if you're interested. I've also acquired a Volvo 850 T5 which will be the direct replacement for the BX
1990 BX 16v
Why bother with something with a pushrod engine and a solid badly suspended back axle? - especially as it was inferior to its predecessors.
Sorry - I thought the barely better than Mk 1 Ford Escort spec of these things was one of the nails in the BL coffin when announced. Just old I suppose.
Jags are much better!
csg100
Post by csg100 »
Because they look gorgeous, have got a legendary v8 engine, make a great noise, are RWD and the rear axle does it's job suprisingly well. As for being inferior to it's predecessors thats a matter of opinion. And it's got c/l, e/m, e/w, PAS. Higher versions got trip computers, air con, leather, e/s/r etc - bit better spec'd than the mk1 Escort me thinks!
And I don't like older Jags much.
Horses for courses I guess. But thanks for your useful input.
1990 BX 16v
mountainmanUK
Post by mountainmanUK »
I'd rather have an old P6, in top spec!
Like you said....horses for courses.
tim leech
Post by tim leech »
csg100 wrote:Thanks, took me ages to write that!! :)
Excellent choice that Carl, Im on the SD1 stand this year at the NEC with my motor, make sure you come say hi! 8)
csg100 wrote:Because they look gorgeous, have got a legendary v8 engine, make a great noise, are RWD and the rear axle does it's job suprisingly well. As for being inferior to it's predecessors thats a matter of opinion. And it's got c/l, e/m, e/w, PAS. Higher versions got trip computers, air con, leather, e/s/r etc - bit better spec'd than the mk1 Escort me thinks!
:lol:
Told
Post by cavmad »
Someone's been owned there methinks.
Right, back to more pleasant things, and people: Carl, is that an early series two model? I used to be able to tell the difference but memory is fading fast! Not been on Overbore 'properly' for a while (sorry Kitch :oops: ) but I'm going to now to catch up with the details of your SD1. Nice to see a car like that, always liked them.
Had a Jag by the way (series 3 XJ6 4.2 auto) and loved it but I'd be majorly suprised if the build quality was better than an SD1.
Comparing it to a Mk1 Escort is both ridiculous and futile: a bit like saying a Transit van is as good as a Ferrari because they both run on 16" wheels.
Vauxhall apologist.
csg100
Post by csg100 »
Yeah, it's an early series 2 (1982 X reg) 3500SE. I too have always liked them and this one came up for a good price and I couldn't resist :)
1990 BX 16v
*goes into soft focus mode*
My first car was an '84 SD1 V8 Auto Vanden-plas. Bought for the massive sum of £60. Fantastic great big barge that it was. Felt quite light and easy to drive for such a large car (although did handle surprisingly badly on the limit, but then that's not what a luxobarge is for)
IMO Jags of a similar period (IE designed in the 70's, sold in the 80's) where throwbacks. They still had an engine designed just after the war, an IRS system that was a nasty compromise, an archaic driving position, etc etc. The SD may not have been as technically advanced but at least it was a fresh design with a relatively recent engine, and had a decent high trim spec available.
After all, a Jag and a Rover could never compete properly for the same market share, as they were both bits of the fast-disintegrating BL group.
I also think the SD1 looks bloody fantastic.
*aah nostalgia. It's not what it used to be*
tim leech
Post by tim leech »
:lol:
Told
Seconded, plus you can get a nice V8 Sd1 for £1000! :D (not mine I hasten to add) Any 80s Jaguar build quality was as bad as any Rover of the time after owning a 87 XJ40, yes mechanically it wasnt advanced but a very easy motor to work on the V8 is pretty bullet proof if maintained regularly.
csg100
Post by csg100 »
Back on topic....
Unfortunately the BX didn't sell. So it's back on for one more try, with a lower reserve.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0143069819
1990 BX 16v
tim leech
Post by tim leech »
Still dont like the strap line mi16 for 205/309 Carl, thats just asking for it to be broken up dude! :shock:
