Looked at the Haynes manual and section says to refer to another section which dont exist. Again I miss my older version of the Haynes manual.
Basically the 19TZS with Air Con is running at 1200 rpm ideal which is to high.
Funny you say that yes she is a bit of a pig to start in the cold or from cold.ellevie wrote:http://www.rwbsmith.plus.com/citroen2/C ... /carb2.pdf
warm idle --- page 222 Fig.16.9 item 1
cold idle (fast idle) --- page 223 Fig. 16.11 item 4.
Have you still got cold start problems ?
