Drivers Window Motor
tim leech
Post by tim leech »
Anyone got a new one they have scurried away? failing that a good used one please, the one on my 16v wont put the window up unassisted now so I need to replace it.
Thanks
I think I have one, I'll check. I think it's driver's side.
tim leech
Post by tim leech »
Thanks matey, have your manual and your red trim to post to you yet, forgot to include it in with the wheel.
I'll venture into the shed this weekend and hopefully unearth it!
kermit the frog
Post by kermit the frog »
If phil hasn't got one i may have one tucked away some where.
Regards Kermit :) :) :)
tim leech
Post by tim leech »
Thanks, Phil the p.o. came today thanks, did you find a motor?
Hi Tim, as I said I'll try to dig it out this weekend. :D
tim leech
Post by tim leech »
Thanks matey!
x 103
the irony is that even if your motor is weak, its likely only a symptom and not the cause. These motors are very good, and should pretty much last forever unless there put under increased load.
tim leech
Post by tim leech »
And the fix for that is?
kermit the frog
Strip out the door.( to make it easier to remove the regulator tape the window to the top frame with tank/duck tape)
remove the nuts around the motor end of the regulator 4x10mm
remove the regulator (this is a bit trick)disconnect the wire from the motor
untape the glass and carefully remove upwards from the door.(clean edges of glass)
look at the pivot on the window regulator.
remove the rubber channel from the door and clean it out in soapy water.
clean out the channel into which the rubber fits.( dry the rubber and spray some pledge or mr sheen in the glass side flock covered part of the rubber
refit the rubber channel taking care to line up the top rear corner make sure it is fully home.
grease the runners and make sure the rollers on the regulator and the window are clean rust free and well greased.
fit the glass in reverse of its removal make sure that the glass is in the rubber channel at both ends and that is moves up and down freely.
retape the glass or if you have someone helping get them to hold it.
refit the regulator reconnect the wire( the tricky bit is getting the rollers in the two channels on the window and in the channel on the door skin at the same time) (the small channel on the door is adjustable to get the glass running up the door corectly 1 x10mm nut)
this is not an easy job but the satisfaction when your window goes up and down with ease its worth the cuts and swearing
clean the glass and refit all internal parts and robert is your mothers brother
I have found what I think is a drivers side regulator/motor and will send it. Sale or return so to speak. Just cover the postage (and if you don't need it in the end there's the National to return it).
Keeper of the site Goat
Post by cavmad »
tim leech wrote:Please could you tell me what the fix for that is?
:roll: :wink:
Vauxhall apologist.
tim leech
Post by tim leech »
I mean I know how to change the motors, done about half a dozen before, but if theres something causing the motors to fail I would be interested.
The drivers window on my BX was rather slow when I bought the car. The cure - silicon spray on the guides and especially the inside and outside of the seal at the base of the glass. This treatment lasts me about a year when I simply repeat it.
How long has this been going on - about 9 years now!
Even a new motor won't wind the windows fast if the glass is sticking in the guides.
