Mk II Front O/S wing needed..
themildbunch
Post by themildbunch »
Hi - after a little accident with a parent and my outer wing left on their drive on a welding day I now need a new Front O/S wing! It fits, just, but doesn't look pretty..
Preferably in Metallic grey, if I'm really lucky, - have to check the paint code later...
It's for an estate but I'm sure the front wings are the same - the rubbing strip is wider but I don't expect they changed the panel pressing just for a different trim design...
thanks
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
KevR
Post by KevR »
Estate wings are the same AFAIK - if there was any difference it would be as you say, behind the trim strip anyway, and trim strips differ between the saloon as well, depending on the age/model rather than because it's an estate or hatch.
I've got some spare wings, but I suspect you'll find someone with one rather closer to you!
Remind me which is off side again.. :oops:
Post by citronut »
O/S is UK drivers side=right hand side whilst sitting in the car,
Depending on how bad the damage is (can you post up a photo?) I might be able to help with a swap. I have a silver estate which is reasonably tidy, but I'm not too bothered about cosmetics, so I could perhaps put your damaged one on in its place?
Distance may be an issue though, I'm in North Wales and would be reluctant to entrust a wing to a courier as it may end up in a similar state to your current one!
KevR
Post by KevR »
citronut wrote:O/S is UK drivers side=right hand side whilst sitting in the car, regards malcolm
Thank you - I never remember! Mind you, I'll have forgotten again in about half an hour... :oops:
Pretty sure I've got a spare r/h wing, but it'll be in white. And on the wrong side the channel (although that could be overcome if time's not of the essence).
themildbunch
mat_fenwick wrote:Depending on how bad the damage is (can you post up a photo?) I might be able to help with a swap. I have a silver estate which is reasonably tidy, but I'm not too bothered about cosmetics, so I could perhaps put your damaged one on in its place?
Oh, it's not too bad, mushed at the front by the indicator - beat it about as best as I could but it'll never be quite right I imagine...
Frustrating end to a day of trying to make the car better and last longer!
1988 BX 19 Gti 16v
