Right. First big trip for the BX today. Sadly there is a problem - I did 25 miles in it yesterday and it seems to have lost 1 litre of coolant. Clearly the leak wasn't just from the pump. I've got over 60 miles to do just to get to Mat this afternoon, and we're then meant to be heading to Anglesey. I have loaded up with water...
The bleeding seemed successful. 250 miles completed without (serious) issue!
Here's an impromptu BX meet at Mat's house.
The 'problem' list is still quite lengthy on the BX. Pretty much every side window seal is knackered, but I'm hoping replacement doors will cure this. The hydraulic pump seems to be knackered too - replacing the accumilator sphere has not stopped the pump from running almost continuously. However, when I collected the new tailgate, I was able to get a second-hand pump as well. £20 the pair. Sorted!
Before undertaking any more big trips though, I need to sort the suspension out. I think the RH strut top mount is knackered, though I now have replacements. I also now have some replacement wishbones, so this should all make a big difference. It handles well enough, but you can feel stuff moving about that really shouldn't!
Overall though, I'm very happy given that this car was sitting forgotten in a garage two months ago.
Frustratingly, I'm getting nowhere fast with the BX. Just haven't got time at the moment to do anything with it, which is likely to be the case until at least November due to a major house project. It has come in useful for jump starting a reluctant Range Rover on several occasions!
One thing I do need to do is drop the coolant flush and actually get some anti-freeze in there. Instructions said to leave it in for 15 minutes 'or longer.' Well, it's certainly been longer...
It's got rather chilly of late, so I finally dropped the coolant flush and bunged some anti-freeze in. I suspect my mixture is a bit too weak - I ran out of anti-freeze - but I still need to replace the fan switch at some point and fit the temperature gauge sender, so will get an opportunity to increase the mixture when I finally do that.
Does definitely feel a bit sluggish. Fuel filter change is a high priority.
Stinkwheel
Can i just say i really like your estate Ian. Even if it has faults, its lovely.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Indeed, hats off tto you mate, shame your not in the CCC as you and it are in Octobers BX'Clusive!Dollywobbler wrote:Yes, you certainly can say that! I happen to agree entirely. Just looking at it squatting on the driveway makes me smile.Stinkwheel wrote:Can i just say i really like your estate Ian. Even if it has faults, its lovely.
Um, any chance of getting a copy of that one? Cheeky I know, but I could always claim it's for journalistic reasons!
Anyway, the BX has been working hard today, with a huge ladder bungee chorded to the roof!
My mate gave me the crossbars, but didn't really have the right connectors for it. Somehow bodged it on and then lashed the ladder to it (while feeling very glad that I only had a gentle drive of about a mile!) but it'd be nice to be able to do this properly...
