I meant to say about wheel trims at the Xrally ,
god knows what your car is meant to have Ian but I have a set of spare ones from my meteor if you want them ,
dont want anything for them except postage ( unless the BX courier service reaches your parts
same as these
same as these
- saintjamesy89
198x Citroen BX16 TRS auto
1991 Saab 900 16v convertible
2007 Lexus RX 400h SE - x 123
Aye. I've got LOADS of wheel trims. Number 6 and Number 3. I worry about them falling off though, so hadn't bothered fitting them. I've also got Peugeot wheels on the front end at the moment, though I think the tyres are a bit hard (they were a freebie from some kind soul on this forum so I'm not complaining!) so I will put new tyres on the correct pair of wheels at some point. As funds allow!
- x 141
Mk1 R and TR models had no "3", which is what was on the DTR before it gained the alloys.
As an aside. The Maverick is in my garage at the moment because it's raining so much and I needed to work on it. That means the BX is sitting outside. I'm pleased to report that the Mothman-supplied replacement driver's door seal does indeed seem to have stopped water pouring into the rear wheelarch (it was gushing in near the front seatbelt lower mount).
The back of the car is still full of stuff (including a door...) so I haven't yet been able to check under the rear seat. It was getting very wet in that area.
Bizarrely I'm the opposite - if I have a car in the garage and I need to work on another, I'll generally choose to work in the rain. Two reasons; I find it a bit claustrophobic working in our garage, and if I shift the dry car out into the rain I'll have a choice between putting it away wet, or leaving it in the rain for weeks. So far not stopped raining (during waking hours at least) since Sunday
Frustrating day. Mr Fenwick kindly lobbed another accumulator onto the BX. No change. Tick time still 5 seconds at best. Oh well. At least it looks like I've got two good accumulator spheres!
Changed the driver's door. Had an absolute nightmare with the lock linkages, and the window fell off its runners at one point when testing. Got there in the end (the proper hinge pin tool really does make life easier!) btu when I got back home, found the internal handle wouldn't operate the lock. Grrrr!
Steering issue seems to be getting worse and various bearings are getting noisy - though I suspect this has more to do with the new, air-leak free window seal allowing me to actually hear them rather than any sudden onset. My feeling is that one front wheel bearing and possibly the alternator bearing are making more noise than they should.
Starting to think it's time to move this one on. It's a great project, and I will always be very glad to have played a part in saving it, but I'd just like to own a nice BX! I know I've downplayed their attributes before, but I'm quite interested in trying a turbo diesel for a bit...
It could be a decision I regret though - I'm hardly going to find another! While trapped in the house by the weather, I have been doing much soul-searching.
