£40 winter restoration
mark239
Post by mark239 »
I'll get shots up of the rest of the fleet (2 more 16V's - one a phase one), 1 x 1985 1.6RS in immaculate condition, and a 1990 1.4 TGE in great shape, but thought I'd start with what I'm prepping as a daily driver.
The post below is an amalgamation of posts from another forum where I'm documenting this, so please excuse it!!
She's a 1990 Phase 2 BX 16 valve, the body is absolutely immaculate underneath, paint is faded though, but it looks like it will polish up.
Engine bay was full of leaves, but the body and chassis is absolutely perfect.
The car has the wrong (A phase one) rear bumper, but there is a rear phase 2 bumper in our massive pile of BX parts so it's all good.
Plans are new liners (It has 102k miles on it so due a rebuild although the leakdown was good, it may as well get freshened up now), stem seals, new piston rings, put my spare Jenvey throttle bodies on her, Emerald K3 ecu and new hydraulic return pipes. Will make a nice retro daily driver. Should be nippy enough at that to see off most modern 'hot' hatches.
rear shot, light clusters are in the boot.
Interior is in great shape - ignore the stuffing on floor! Was from the spare interior being stacked in it
needs a good tidy up in the bay, but everything works.
spare phase 2 bumper laying in a shed
Only just getting to do something to this now! Didn't get a lot done today, just started to strip down - got the new radiator in as well though.
Will be getting the head off tomorrow then the pistons out to put new rings on. Will need valve stem oil seals as well.
Then it's on with the Jenveys and the sporty inlet cam!
Engine before
Inlet manifold off
http://www.mark-chapman.com/uploads/d6cafter2.jpg" onclick="window.open(this.href);return false;
Injector harness off
New rad installed
http://www.mark-chapman.com/uploads/newrad.jpg" onclick="window.open(this.href);return false;
Made some progress today, got the head off and was pleasantly surprised by the liner condition.
A hone should be all I need to do to them before firing on the new gapless rings.
Had a bit of bother with one of the bolts, some bellend must have had at them before with a poor fitting driver and broke a bit off it. Will be replacing them anyway
Cam cover off
The f**ked head bolt on right hand side
liners are better than they look here
head off on the 'bench'
8 into 1 exhaust manifold (Standard)
Got the barge into the garage with the lift today, got the non standard front bumper off and stuck a new door seal on the drivers side.
Bodywork won't start until after all the mechanicals are perfect.
underside of the car is completely rot free - you'd think it had been kept in a bath of oil!!
Anyway, few pics
Outside at last (You can see how well the paint is going to come up - i did a test patch on the bottom half of the drivers door, it's coming up like new, and that was the worst bit!)
New drivers door seal on
Dozing her into the shed (Brother driving the quad)
in the garage at last for the fun to begin!
Got an hour this evening to get a piston out to send off to get the correct sized gapless rings.
Tightening down the improvised liner clamps
Bores are in very good visual order!!
Piston out, connecting rod off
Big ends in good order as well
In the box ready to get a new set of rings
Started to get a bit more done today with the head
Lifters out
Taking the valvetrain apart
The ECU she'll be getting
the TBs I'm transplanting into it for epic sounds
mark239
Re: £40 winter restoration
Post by mark239 »
Got the head back together at least this weekend
The valve collets were ridiculously tricky to get in with a normal spring compressor and small screwdriver with grease on it!
Valves in and springs mostly in
'special' stem seal tool - 10mm socket
fully assembled, bar buckets
test fitting the piston rings once gapped - note the top ring is in 2 pieces, a rail on top and the ring below that forms a gapless ring.
Putting the buckets back in
camshafts back in
oil spray bar back in
Unfortunately it looks as if I will have to replace at least one liner, as the ring clearances uncut were too great, so going to have to look about that this week.
High lift inlet cam has been ordered but going to take 4 weeks to arrive, so building up with standard cam for the time being.
This week I should have the engine back together assuming I get the liner(s) I need.
mark239
Post by mark239 »
I'm currently waiting on a set of new liners.
I ordered the ones from a 1.9GTi, and a set of big end bearings - total cost was a rather pleasurable £200 - bit better than proper D6C liners....
Wow! Good work and welcome aboard Mark, any pics of the Mk1 16RS?
Tim Leech wrote:Wow! Good work and welcome aboard Mark, any pics of the Mk1 16RS?
..that_ . . . and good luck with the rest of the restoration - look forward to seeing the finished article.
Great post & fantastic pictures. Looking forward to seeing more :) And can we have pictures of your other motors as well, so we can erm lust at them or something, haha...
Blimey. What a superb first post! (and second, and third). Loved spotting other Citroens lurking. Did I see a Mk1 BX and a Dyane?
(ah, I see you mentioned a Mk1 BX in your first post. Spotting fail!)
mark239
Post by mark239 »
The black 16V
Silver BX 16V phase1
I'll get pics of the other 2 by the weekend, they're at the parent's house under the covers - you can just see the Mk1 RS in the top pic in my first post, and the white 1.4 is under the cover in the photo where my brother is pushing the car into the shed.
The pride of the fleet is this money pit: (Yes, that's an activa in the background)
mark239
Post by mark239 »
And yes, that is a Dyane, the brother owns that - he restored it to as new a few years ago. It's 1981 I think.
That mk1 16RS didn't come from N.Ireland by chance?
mark239
Post by mark239 »
Kitch wrote:That mk1 16RS didn't come from N.Ireland by chance?
I'm in Northern Ireland! It came from England.
We also had another Mk1 but it was pure rotten so was scalped for parts then scrapped.
You didn't buy it around about 2007 by chance?
mark239
Post by mark239 »
I cant remember how long ago we went over to get it!
We went to lift it in eastleigh. I think that's where it was, and it was a mad dash back to Holyhead for the ferry!!
It must be a good while ago as I was using a Dell axim with tomtom installed as GPS.
Ah right yeah, this one?:
I'm the guy you bought it from! :lol:
Awaits tales of it blowing up, rotting out, catching fire etc etc
mark239
Post by mark239 »
Haha! no way - thats the one !!!
Small world that's for sure.
