I think I shall try and speak to the garage first with a view to taking it up there.saintjamesy89 wrote:Wow, you must be the most local BX to me! I know of a very good and knowledgeable bloke in Yeovil (where I live), the garage is East Coast Garage and I have taken my BX in before, edned up talking for a good half hour about BX's and citroen's, he has an X1/9 too.
I work in Shepton Mallet, closer to you than Yeovil so if you want to pop over to hear the noise a HP pump should make you're more than welcome. Could be a tired pump, does the system leak anywhere?
i think i have a handle on the noise now, I think I will just have to keep driving the car until I fix it or it breaks in the short term, which isn't an issue as I have breakdown cover and other cars I can use.
I will try and check the leak back to the Lhm tank tho, which may be a clue.
