1984 BX 16TRS
1984 BX 16TRS
Thought I'd do a quick gallery post of the new arrival. I've already plastered Facebook and my blog with some images, but thought they're fairly easy to miss for passers-by, so here we are!
Still has the protective sheets on the rear carpet!
No rear seatbelts, something I'll have to rectify. The fronts are grey/black block patterned, so finding rears to match that will be nigh-on impossible!
It does run (quite sweetly in fact, but then it should for 17,000 miles!( but the carb needs setting up. It also needs four new tyres, as they're the ORIGINALS! It has a catastrophic LHM leak too, one that prevents it from lifting. Won't be doing anything with it immediately, it's more a case of securing it as it's a model/spec I always wanted. But next year I plan to be driving it around :)
Re: 1984 BX 16TRS
Post by Tinkley »
Hold on Kitch, my 'originals' as in tyres (Michelin MXL) on the 14 did 72K front 108k rear, I'd complain to Michelin.. :lol:
Re: 1984 BX 16TRS
Tinkley wrote:Hold on Kitch, my 'originals' as in tyres (Michelin MXL) on the 14 did 72K front 108k rear, I'd complain to Michelin.. :lol:
Maybe, but I'm sure they weren't 30 years old :lol:
Re: 1984 BX 16TRS
Post by Tinkley »
Well they still advertise a long life.. :lol:
jeremyC5
Re: 1984 BX 16TRS
Post by jeremyC5 »
It's the sunlight that degrades them and makes them crazed and split.
I had four on my triumph herald, for 12 years always parked the same way round, the two on the sunny side are completely shot, but the two on the dark side are perfect !!
C5 x 1
Ford 100E - Red x 2
Herald 12/50 x 1
Re: 1984 BX 16TRS
Post by Tinkley »
Ah, the Dark side he takes!..... :lol:
jamescarruthers
x 23
Re: 1984 BX 16TRS
Post by jamescarruthers »
Your seatbelts don't look like this do they?
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
x 141
Re: 1984 BX 16TRS
No radio?
Re: 1984 BX 16TRS
jamescarruthers wrote:Your seatbelts don't look like this do they?
They do James, yes
Re: 1984 BX 16TRS
Tim Leech wrote:No radio?
No, I noticed that. It's got a black plastic oddments tray in there....
jamescarruthers
x 23
Re: 1984 BX 16TRS
They do James, yes
In that case, it's good news as these belts in my car (front and back) came from a Mk. 2 TRS spec car. It was white with tabac interior (the one GaryC broke). You'll need to work out if it is TRS spec or white tweed that has these belts in them but you should be able to get hold of a set.
They bolted straight in the back of the car in about half an hour with the rear boot trim removed.
P.S. Your 16TRS looks great by the way. Hope you get it on the road next year. I used to have A966 XRL, a 1984 16TRS, looked just the same.
1987 Volvo 480 ES
Previous BX's:
B316 AMP -- BX 14 E
x 141
Re: 1984 BX 16TRS
No Mk1 came with a radio fitted from the factory, they were all dealer fit.
PhilGreaves
My Cars: CCC X**tia Columnist!! forgive me for I was led astray..
1984 Citroen BX 16TRS restored and now with fully functional power steering..!
1994 Citroen Xantia 1.9 TD SX (Jan 1994, no airbags but antisink fitted)
Re: 1984 BX 16TRS
Post by PhilGreaves »
oh its still around :wink: . Reckon you may see it this year.....just a question of when... :shock:
looks great kitch good luck with it. I'm sure you must be one of a very few people who can get it ship shape and I look forward to seeing it in the metal sometime! In fact id love a photo of it next to mine and James' 14...I know how sad am I..
best of luck!
Phil
regards
Phil & Earl
1984 Citroen BX 16 TRS mk 1 "Earl" restored sept 2011 and now with fully functional power steering..!
1994 Citroen Xantia 1.9 TD SX (Jan 1994, no airbags but anti-sink fitted)
Re: 1984 BX 16TRS
Nor did the early MK2's. :( My brand new E reg GTi came without but was quickly fitted with unit/speakers of choice when I got it home. :)
Re: 1984 BX 16TRS
Cheers for the heads up James.
Hopefully it'll be on the road next year, not in a pristine form or anything, but something approaching usable :lol:
