Can anyone recommend some good quality speakers i can fit to my TZi front doors that will fit in the old apertures and behind speaker grille covers.
Thanks.
Front Speakers
Front Speakers
- x 113
Re: Front Speakers
I use Alpine 1325s 5.25 inch speakers. They are reasonable quality and the right size and definitely better than the originals.
I might have a spare pair somewhere..........
Re: Front Speakers
Thanks John
If you find them and they are serviceable and wish to part with them please let me know and I will pay pal you.
kernowtim
- My Cars: BX 19 estate
1999 ford focus 1.8TD
Re: Front Speakers
just fitted pioneer ts-g1315 13cm 5 1/4 inch dual cone speakers in my estate, straight swap for original ones whose cones had broken up, had to crimp up one of the connectors which was slightly loose but otherwise no problem fitting.presumably any brand this size should fit,, carefully lever off the grills about an inch from the top on both sides to remove, 4 crosshead retaining screws underneath
- x 113
Re: Front Speakers
OK I will have a hunt for them.Tim Leech wrote:Thanks John
RobC
- x 30
Re: Front Speakers
I tend to find that modern speakers have larger magnets at the back, necessitating cutting into the seal behind, which should then be resealed somehow if you're a purist and/or want to keep the damp out.
