Front Speakers
x 148
Front Speakers
Can anyone recommend some good quality speakers i can fit to my TZi front doors that will fit in the old apertures and behind speaker grille covers.
Thanks.
x 83
Re: Front Speakers
I use Alpine 1325s 5.25 inch speakers. They are reasonable quality and the right size and definitely better than the originals.
I might have a spare pair somewhere..........
x 148
Re: Front Speakers
Thanks John
If you find them and they are serviceable and wish to part with them please let me know and I will pay pal you.
kernowtim
My Cars: BX 19 estate
1999 ford focus 1.8TD
Re: Front Speakers
Post by kernowtim »
just fitted pioneer ts-g1315 13cm 5 1/4 inch dual cone speakers in my estate, straight swap for original ones whose cones had broken up, had to crimp up one of the connectors which was slightly loose but otherwise no problem fitting.presumably any brand this size should fit,, carefully lever off the grills about an inch from the top on both sides to remove, 4 crosshead retaining screws underneath
x 83
Re: Front Speakers
Tim Leech wrote:Thanks John
OK I will have a hunt for them.
x 148
Re: Front Speakers
Thanks John,
I wait to hear from you.
RobC
My Cars: 1991 Citroen BX 16v
x 26
Re: Front Speakers
Post by RobC »
I tend to find that modern speakers have larger magnets at the back, necessitating cutting into the seal behind, which should then be resealed somehow if you're a purist and/or want to keep the damp out.
x 148
Re: Front Speakers
Now sorted thanks to Jaba.
