16v rocker cover gasket
- x 26
Mine's leaking. From a quick search there seem to be two extremes in price: spoox components are asking a ludicrous £50+ for a genuine Peugeot one, while I can find others of questionable brand on eBay for around a fiver.
There must be a happy median somewhere? Any suggestions...?
- x 88
Re: 16v rocker cover gasket
Cheap one off eBay!
Tube of blue Hylomar even cheaper.
- x 88
Hylomar alone wouldn't seal a 16v cover. Worst case pop some on with the cheapo gasket.
- Jaba
- x 82
I have taken to using high temperature silicone in a standard cartridge gun on all gaskets and hoses. It seems to work well even on sump gaskets.
- JayW
- x 13
One's off eBay are fine, mine fits fine and dint leak!
- x 26
Thanks for the replies. eBay it is - driving to Montpelier next week so if it all starts pissing out and destroys the engine on top of the Millau viaduct, I'll let you know...
- JayW
- x 13
I'll buy a framed print if it does!RobC wrote:Thanks for the replies. eBay it is - driving to Montpelier next week so if it all starts pissing out and destroys the engine on top of the Millau viaduct, I'll let you know...
Millau. Lucky bugger.
- x 26
Well that didn't work - £5 off ebay gets you completely the wrong part!
This one looks a bit more promising though. http://www.ebay.co.uk/itm/PEUGEOT-405-1 ... SwIgNXjEx-
- x 88
I can't even find a 16v gasket on there for a fiver!
- x 26
They come up if you search for Mi16.
For the one I bought in error, I assumed (in error) they just had the wrong graphic in the listing, but that the actual part would be suitable. More fool me - £5 was always going to be too good to be true.
- JayW
- x 13
391115772092 is only a tenner with quick post.
- x 26
Ah good spot! darn, I'd just ordered the £20 one yesterday.
- JayW
- x 13
I almost always find better deals by searching part numbers rather than descriptions. There are some proper bargains about when they are listed with little effort.
- x 26
Just got back, 1800 miles later.
Despite the weeping gasket she didn't seem to use a drop of oil. Only hiccup was the oil temp gauge sender wire deciding to break.
Only saw two other BXs during the entire trip! A few waves from other appreciative French drivers though (at least I assume they were waving to say hi rather than anything less pleasant).
God I love driving this car.
At one point the temp gauge was showing 65 when descending the Massif Central, even in 28 degree heat. Perhaps a new thermostat is in order.
