There must be a happy median somewhere? Any suggestions...?
16v rocker cover gasket
RobC
- x 30
Mine's leaking. From a quick search there seem to be two extremes in price: spoox components are asking a ludicrous £50+ for a genuine Peugeot one, while I can find others of questionable brand on eBay for around a fiver.
1991 Citroen BX 16v
- x 94
Re: 16v rocker cover gasket
Tube of blue Hylomar even cheaper.
- x 94
Hylomar alone wouldn't seal a 16v cover. Worst case pop some on with the cheapo gasket.
- x 117
I have taken to using high temperature silicone in a standard cartridge gun on all gaskets and hoses. It seems to work well even on sump gaskets.
JayW
- x 13
One's off eBay are fine, mine fits fine and dint leak!
RobC
- x 30
Thanks for the replies. eBay it is - driving to Montpelier next week so if it all starts pissing out and destroys the engine on top of the Millau viaduct, I'll let you know...
1991 Citroen BX 16v
JayW
- x 13
I'll buy a framed print if it does!RobC wrote:Thanks for the replies. eBay it is - driving to Montpelier next week so if it all starts pissing out and destroys the engine on top of the Millau viaduct, I'll let you know...
Millau. Lucky bugger.
RobC
- x 30
Well that didn't work - £5 off ebay gets you completely the wrong part!
This one looks a bit more promising though. http://www.ebay.co.uk/itm/PEUGEOT-405-1 ... SwIgNXjEx-
1991 Citroen BX 16v
- x 94
RobC
- x 30
They come up if you search for Mi16.
For the one I bought in error, I assumed (in error) they just had the wrong graphic in the listing, but that the actual part would be suitable. More fool me - £5 was always going to be too good to be true.
1991 Citroen BX 16v
JayW
- x 13
391115772092 is only a tenner with quick post.
RobC
- x 30
Ah good spot! darn, I'd just ordered the £20 one yesterday.
1991 Citroen BX 16v
JayW
- x 13
I almost always find better deals by searching part numbers rather than descriptions. There are some proper bargains about when they are listed with little effort.
RobC
- x 30
Just got back, 1800 miles later.
Despite the weeping gasket she didn't seem to use a drop of oil. Only hiccup was the oil temp gauge sender wire deciding to break.
Only saw two other BXs during the entire trip! A few waves from other appreciative French drivers though (at least I assume they were waving to say hi rather than anything less pleasant).
God I love driving this car.
At one point the temp gauge was showing 65 when descending the Massif Central, even in 28 degree heat. Perhaps a new thermostat is in order.
1991 Citroen BX 16v
