BX 19 TRS Auto Estate "Bertie"
Joris
My Cars: 1995 Volvo 480 ES
1987 Citroen BX 1.9 TRS Estate
1977 Mini
Re: BX 19 TRS Auto Estate "Bertie"
Post by Joris »
rutter123 wrote: Sat Apr 28, 2018 4:02 pm I'll dig the oil cooler out tomorrow.
Many thanks!
Its definatly magnetic blue!
jamescarruthers
x 37
Post by jamescarruthers »
Still will look good when polished up!
1987 Volvo 480 ES
Previous BX's:
A966 XRL -- BX 16 TRS
H767 BEG -- BX 14 TGE
B316 AMP -- BX 14 E
Its a lovely colour, the light blue was always very popular, Romantic Blue before hand and Olympic and Ice blue which followed it.
Joris
1977 Mini
Post by Joris »
It's magnetic blue, that's what the colour code says as well! I still don't really know how I feel about it though..
There has been some updates on Bertie.
I've sourced a new oil cooler of a (scrapyard) Renault Scenic, slightly smaller but should do the job as well (if not, please respond in capitals and exclamation marks). That's all fitted and not leaking, so happy days.
In the month of standing still it all of a sudden decided to have an LHM leak...
Which is a bit of a pain because the octopus has been replaced (by me) with a brand new one about 4 months ago. And it's not a job I'd like to do again.
The end of 1 of the hoses had a small tear and has now split. I've tried to use a petrol hose, which I had to stretch up before I put it the end of the octopus hose, then a jubilee clip on that to prevent leaking.
It hasn't worked, does anybody have any tips? I might try another Jubilee clip next to it...
Other things that have been done.
* Antenna replaced
* Roof rails repainted satin black
* New ignition cables and spark plugs
* New fuel filter
* New air filter (after it got sprayed with coolant)
x 113
You will have to cut off the split bit and join in a piece of new hose somehow. Alternatively using some of that self annealing silicone tape might get you out of trouble but its usually simple to put a join in.
x 138
I used 3mm bore rubber pipe and some push fit barbed connectors, trouble is with that old pipes will split again even if you trim it back.
Joris
1977 Mini
Post by Joris »
Do you just mean something like this?
https://www.advancedfluidsolutions.co.u ... 2227-p.asp
x 138
That's the type, check the i/d of the rubber pipes as they mite have been 2mm, it was a while ago..
Joris
1977 Mini
Post by Joris »
I'll give that a try! Thanks
