x 138
I just looked at mine today still up on blocks of wood, and all sorts of junk slowly being piled up on the roof and bonnet and dust so thick you can barely see thru the windows, I shook my head, switched the lights off and shut the garage door.
Still, the spiders seem quite at home inside the car.
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
x 81
Post by Dave_16v »
Just had a quick sit inside and turned on the Atlanta SQR 47 to have a quick blast of Menswear Nuisance, sounds so much better in cassette.
Pcheaven
x 12
Post by Pcheaven »
Dave_16v wrote: Fri Apr 09, 2021 12:29 pm Just had a quick sit inside and turned on the Atlanta SQR 47 to have a quick blast of Menswear Nuisance, sounds so much better in cassette.
I hear the love of cassette
My current blue point player has no power.
Hope to fix it, or replace like for like. With a hidden Bluetooth unit for my phone.
ToDo list.
Have a GnT
Have a GnT
3. Adjust the clutch
Have a GnT
Have a GnT
Have a GnT
6. Replace rear spheres
Have a GnT
7. Replace bottom hose
x 138
I cleared all the crap off mine, Inc 1 r/c aeroplane, 3 old pictures. 1 old printer, 3 sets of car mats, a sledge, some underlay and the parcel shelf.
Lots of new scratches as well.
frog
x 12
Post by frog »
rutter123 wrote: Fri Apr 09, 2021 4:38 pm I cleared all the crap off mine, Inc 1 r/c aeroplane, 3 old pictures. 1 old printer, 3 sets of car mats, a sledge, some underlay and the parcel shelf.
Are you... me?
Wait, no you're not mine is still under a mountain of things. :roll:
1989 Citroën BX 16v
1993 Citroën BX 16v project
Pcheaven
x 12
Post by Pcheaven »
Removed the broken windscreen spray bar and installed the Mercedes screen wash block.
Much improved screen clean.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Had the DTR for a run to derby to see a mate for a socially distanced Tea and meet his new puppy.
Still need to replace the O/S rack gaiter.....
white exec
My Cars: 1992 BX19D Millesime
1996 XM 2.5TD Exclusive
x 73
Post by white exec »
Left it getting a 'rinse' in the steady rain.
Tomorrow morning: Covid jab #1 \:D/, and collect the A/C O-rings* from Citroen.
* Junta torica in Spanish. Isn't that nice?
Pcheaven
x 12
Post by Pcheaven »
Fixed the blue point radio - power disconnected !!
Wiped down with some LHM. The front struts inside the gator. Apparently this stops the juddering when going up or down. Worked a treat.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
white exec
x 73
I momentarily had visions there of the poor old radio getting the LHM treatment :shock: :shock: !
Some regular road use and a few Citrobics should keep the front struts creak-free, as they will be self-lubricating.
BX today just rested. Rain stopped, now 22°C and sunny.
Friday productive: Pfizer jab, and lots of O-rings.
Hell, I always swore I'd never go anywhere near F*c*b**k. [-X
This thread has a lot to answer for.
Pcheaven
x 12
Post by Pcheaven »
It’s had plenty of citrobics whilst parked up. . The manual lube defiantly helped the radio !!.
Am not driving it at the moment. As I am unsure of cam belt history. Hoping to catch up with Kitch soon as he is replacing my cam belt etc.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
x 116
I charged the battery, cleared out the boot and fitted a small wooden trim, sprayed black, to stop the parcel shelf from trying to descend into the boot space. Checked the oil and water. I still need to have a look underneath before I challenge the local garage with an MOT.
x 138
Cut and shaped 6 pieces of steel sheet ready for welding the o/s sill, chassis rail and axle mounting.
RobC
My Cars: 1991 Citroen BX 16v
x 30
Post by RobC »
Drove 400 miles to SW England and back. Smiles all round!
Pcheaven
x 12
Post by Pcheaven »
Booked in for a cam belt, pump and tensioner replacement. Plus a quick once over the auto choke etc
Can wait to be able to drive it whenever I like when the belt is changed.
ToDo list.
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
Have a GnT
