Well, it' been one of those days today where everything I've touched has turned to s£!t. Started by finishing the wiring looms at the back end of the car, and broke one of the plugs... Then I lost an earth lead that runs down the N/S "C" pillar, still aint found it...
Managed to get the alarm working again but I'm not altogether sure how!
The central locking now all works and the indicators are no longer on all the time.
Then I thought I'd fit the dashboard, although in retrospect I should have finished fitting the roof lining up..
Having installed the dash it didn't look right, after a while and checking the dash in the valver I pulled it out again and refitted, looks better now.
It took about an hour to get the cables on to the heater controller, complete with grazed knuckles and more swearing.
Only then did I notice that the heater tap was seized, so spent another hour working the thing in and out and it now seems to work.
Put the "A" pillar plastic trims on and noticed I could no longer see dur to the sun having bu&&ered off so I packed up.
The panels were all sprayed today so tomorrow I'll collect them and after having some dinner with the boys in 2cv's I'll hoof up to the car and fit a few of them!
Hopefully I can avoid breaking anything tomorrow.......
Chris G
