The large O-ring (No. 11) is 42mm dia, round section, 1.6mm thickness
The small O-ring (No. 13) is 16.4mmx19 dia, square section, 1.3mm thickness
Cheers,
Mark.
Sorry Markmnde wrote:Just to clarify (and get them both in the same post),
Cheers,
Mark.
OK great thanks for clearing that up; it was just that No. 13 looked square section in the exploded diagram.AndersDK wrote:But "The small O-ring (No. 13) is 16.4mmx19 dia, square section, 1.3mm" is not a square section, its a round section.
This is to make it as flexible as possible as its used for compressing the tephlone ring round the piston.
