wanted: The bit that holds the radiator in for a 16V
mark239
Post by mark239 »
As above - need the bit that attaches to the slam panel and holds the top of the rad in
WHY?
Re: wanted: The bit that holds the radiator in for a 16V
mark239 wrote:As above - need the bit that attaches to the slam panel and holds the top of the rad in
WHY?
It rattles and flops otherwise? :?
Mike P
Post by Mike P »
What Have You.
Mike P
mark239
Post by mark239 »
Gave up in the end and made my own.
My friend is a fabricator and has the folding machine I required
Matt H
Post by Matt H »
Toyota MR2?
Loving those throttle bodies by the way!
djoptix
Post by djoptix »
I was about to say "get you with your TBs" too. How does it run on those? Are you using Megajolt?
mark239
Post by mark239 »
djoptix wrote:I was about to say "get you with your TBs" too. How does it run on those? Are you using Megajolt?
It goes great, especially since I totally rebuilt it with new liners etc. Thread is in members gallery here. ECU is an Emerald K3. Megajolt only does ignition, so you'd need to run carbs - but have set a few of these up recently too. Megasquirt would be the equivalent for ignition and fuel.
djoptix
Post by djoptix »
Ah yes, I had completely forgotten your thread! Sorry. And that was probably a stupid question about the ignition, I had just seen the missing dizzy cap and didn't think any further, as if you could use TBS with the standard ECU... duh...
I always meant to ask what you did regarding cams, having re-read your thread you said you were going for something with higher lift but there was no mention of it turning up - did you end up with the standard one in the end? At some point I think I'd like to make my red one go a bit faster (I'd like to get it back on the road in the first place, of course), and I'm thinking the top end is the place to start, but thought that more duration rather than more lift was the best option.
Would also be interested to know what pulleys you have on the cams. Although if you're not RRing it then it's all a bit academic :lol:
mark239
Post by mark239 »
Haven't got a new set of cams yet, a new precision PT6466 for the MR2 has took precedence, and the arrival of a ZX16V to the fold!
mark239
Post by mark239 »
Matt H wrote:Toyota MR2?
yeah, mildly modified MR2 :)
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
Mark, can I ask a question purely out of curiosity? Why did you write WHY at the end of your first post?
BMW X1
x 26
An abreviation for 'what have you' ?, often used when selling cars if the seller is willing to consider part ex-,
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
Ah ha, now I get it. I've seen it on eBay many times and thought I was missing out on yoof speek!
If it makes you feel any better, i was non the wiser either, haha...
