really?
Posts: 111 Joined: Sun Apr 15, 2012 5:45 pm
Post
by really? » Sun May 31, 2015 9:11 pm
Am looking for a nearside cv joint/drive shaft 90 teeth/splines ABS for turbo diesel, getting very urgent.
Alternatively can anybody recommend someone who rebuilds them.
Replaced rebuilt ones on a different car many years ago and they failed again within 5k miles.
Please no mention of hens teeth. I know!!!!!!!
Posts: 4408 Joined: Sun Aug 14, 2005 10:53 pm
Post
by ken newbold » Sun May 31, 2015 10:31 pm
is it just the CV joint hub end you're looking for?
JayW
Posts: 1590 Joined: Thu Dec 07, 2006 6:40 pm
x 13
Post
by JayW » Sun May 31, 2015 11:45 pm
Not rare at all, or expensive. Search J&R trading Driveshafts, always get all my shaft from them.
Posts: 2781 Joined: Wed Oct 31, 2007 7:55 am
Post
by citronut » Mon Jun 01, 2015 10:38 am
have you asked your local motor factors for a new CV joint ???,
Posts: 2695 Joined: Sun Sep 02, 2012 9:54 pm
My Cars: 90 Bx Tzd turbo ven red 295k 74 D Super 5 black 05 Volvo V50 2.0d 180k 65 Peugeot Boxer work van 280k
x 138
Post
by rutter123 » Mon Jun 01, 2015 4:15 pm
Got mine for the t/d from a place in Birmingham, new off the shelf for £30 plus pp, will try to find the receipt, is the same as a gti being the slightly bigger diameter shafts. 40k's on still ok.
really?
Post
by really? » Mon Jun 01, 2015 6:35 pm
Thanks for replies.
Before I asked, explored Citroen and motor factors and no joy.
Have heard of J and R in Birmingham and then read some very worrying feedback about their joints so thought I'd try here first and if all else fails will have to bite the bullet and go for remanufactured aftermarket ones.
It is the CV joint itself which is clonking, it may be easier to just buy the whole driveshaft with new joint, we did fill with new grease but of course they don't heal themselves.
Really's Mum
Post
by ken newbold » Mon Jun 01, 2015 10:20 pm
Can probably get you a good used one if you can hang on a couple of days
JayW
x 13
Post
by JayW » Fri Jun 05, 2015 12:12 am
I've had more than a dozen shafts from J&R over the past 5 years or so and of the cars I'm still in touch with, not one of them has had a problem.
really?
Post
by really? » Sun Jun 14, 2015 4:55 pm
Hi Ken have just seen your post, sorry, have been working away again for two weeks.
Do you still have a good used nearside driveshaft with the 90 splines for abs?
If you do please pm me.
Thanks
really?
Post
by really? » Tue Jun 16, 2015 6:27 pm
Hi all, bit the bullet and bought a driveshaft from J&R, it arrived today.
WRONG ONE.
Having phoned them to explain they admitted finally that they do not do the one with 90 splines. Very good communication no problems dealing with them at all.
Back to square one again.
STILL LOOKING
Posts: 2025 Joined: Tue Jul 05, 2005 7:54 am
My Cars: BX GTi, C3 Auto
x 113
Post
by Jaba » Tue Jun 16, 2015 10:57 pm
You can get 90 segment reluctor rings to convert standard CV joints. Saw them on ebay a while back from a german seller.
Also various French sites used to list ABS drive shafts. There is a couple showing on Oscaro for example and piecesavanue.
Link to pieces avenue :
http://citroen.piecesavenue.com/bx-xb/1 ... ansmission
Oscaro I think are a bit cheaper but it depends on shipping of course :
http://www.oscaro.com/cardan-citroen-bx ... 706-936-gt
Have you tried Edwards , BX breaker in Essex ??
Post
by ken newbold » Wed Jun 17, 2015 6:05 pm
I thought it was just the cv joint end that you need?
really?
Post
by really? » Wed Jun 17, 2015 6:31 pm
yes it is the cv which is badly worn, drive shaft itself is ok
really's mum
Post
by ken newbold » Thu Jun 18, 2015 10:20 am
90 splines seems an aweful lot, an chance you could post a pic showing the shaft "end-on" ?
really?
Post
by really? » Thu Jun 18, 2015 6:33 pm
90 splines is a lot but is normal for tzd turbo with abs, same I believe as gti.
Am in Brighton with the shafts on the car, using as a daily driver till I find the correct part and replace it.
Pics impossible at the moment but believe me it has 90.
