BX 16 Automatic
trecasi
My Cars: Citroen BX16 TGS Auto
Citroen C3 Aircross (wife's car)
BX 16 Automatic
Post by trecasi »
My BX 16 TGS Auto has developed a big leak of Transmission fluid. Does anyone know of any specialists, preferably in the Northwest ?
panky
'88 BX GTi (a long time ago)
x 169
Re: BX 16 Automatic
Post by panky »
I've no experience of them so can't personally recommend but there's Westroen in Manchester, they seem to get good reviews from others.
https://www.westroen-spheres.co.uk/
trecasi
Re: BX 16 Automatic
Post by trecasi »
Thanks for that - but they only deal with the hydraulics, not the gearboxes.
My Cars: BX GTi, C3 Auto
x 113
Re: BX 16 Automatic
I would get a diagnosis of where it is leaking from first then you know what you are dealing with. It might just be a driveshaft seal.
x 53
Re: BX 16 Automatic
Post by David »
As Jaba says, try to find out where the leak is coming from first.
More than likely, it’ll just be a seal. The driveshaft seals are easy enough to replace & readily available.
It could be a rusty oil pan, in which case you’ll need to replace it.
Otherwise it could be coming from the oil cooler, the seal below it, the dipstick, the oil pan gasket, or the torque converter oil seal, but that would be difficult to repair as you’d need to remove the gearbox to get to it.
I don’t know where abouts you are, but there is an automatic gearbox specialist in Denton, Manchester, near the crown point shopping centre. As far as I’m aware, they’ll be able to fix anything gearbox related, but they might not be familiar with the BX in general.
Hope that helps.
trecasi
Re: BX 16 Automatic
Post by trecasi »
Thanks for the information on possible causes of leak - it has turned out to be a cracked casing as a bolt had dropped in to the box then knocked its way out.
I have sourced a new gearbox and it has been fitted, so now I have a fully working car again.
x 113
Re: BX 16 Automatic
Great! All's well that ends well
panky
x 169
Re: BX 16 Automatic
Post by panky »
Good news getting it sorted.
A bolt made a bolt for the exit :shock:
