Front indicator removal
white exec
Am I right in thinking that it's necessary to first remove a headlight, to get access to securing bolt for the late-type indicator unit? Early units unclipped, but looks as if late-type have a side securing bolt/nut.
Dave_16v
BX 16 valve Ph 1 past
BX Gti past
BX Gti Auto past
ZX Volcane keeping others going - x 78
Re: Front indicator removal
That appears the way. Just had a look at mine, there is a gap, I think you could get the nut off with the certain spanner but retaining it and refitting will be a challenge. It is not something you do often but I am sure I have had the headlights removed on the occasions I have removed a indicator unit.
white exec
Dave_16v
BX Gti past
BX Gti Auto past
No, not hard at all and a good opportunity to give the area a little clean.
white exec
Am looking at fitting some discreet DRLs into the lower part of the indicator units.
Good few of our winding blind-bend mountain roads here really need some extra front-end visibility these days. Daytime headlights are a bit OTT, and use of front fogs (if I had any!) are not legal here when visibility is good.
I also wanted to keep the external appearance of the car as original as possible, hence the idea of using the corner units. This also has the benefit of lighting at the full width of the car, which can be useful when some clot takes a corner wide...
The fittings will likely get 2 x "50W" T10 warm white LEDs each, which will operate full-on in daylight, but drop back to side-light brightness when lights are turned on. While an indicator is flashing, the DRL in that fitting will extinguish. The O.E. parking lights in the headlights will be off for normal driving, but will work as parking lights and when the DRL system switches off. A small plastic box and a few relays will do the switching, with a few external connections.
Did a similar system for the XM a couple of years ago, with the same double T10's in its front sidelights. Simpler there, because no need to interrupt the DRLs for indicating, as they are in well-separated units, and the new LEDs (dimmed) also function as side/parking lights.
- x 113
Clever idea. I sometimes feel a bit vulnerable in the BX when nearly all the cars nowadays have daytime driving lights a non lit up car could be missed by a modern motorist used to seeing cars fitted with fairy lights. In fact I almost always drive with dipped headlights these days if it is at all gloomy or I am in hills or mountains. Its safer that way.
TizzyD
- x 10
Would it not be easier just to use the dim-dip function already built into the car ?
white exec
Did consider that. DRL has the advantage that pinpoint bright lights, especially at the outer extremities of the vehicle, give oncoming drivers a really rapid reading of the vehicle's position on the road, and an unmistakable cue to take any necessary avoiding action.
Given the winding and blind bends of our 21km local main road here (which I have to drive 9km of several times each week), and the number of young idiots in small Audis and Seats who use it as a race-track, my main priorites are: be seen, be on the right side of the road, and - importantly - be able to be rapidly stationary when hit*. Fortunately, Citroen brakes help no end with that last!
* This automatically (here) throws responsibility for the collision on to the other driver, so protecting one's own NCB.
TizzyD
- x 10
Ah fair enough, post pics if you get it to work
white exec
BX 16v Ph2 - XPO - x 103
From the description, it sounds like that would let white light out of the sides of the indicator. That would be illegal in the UK (if anyone cared enough), would it give you the same problems?
You can get a DRL strip that fits perfectly between the bottom of the headlight glass and the bumper, across the width of the headlight. It can also do dual colour as an extension of the indicator. Might be a perfect off the shelf solution.
white exec
Thanks, Vanny - I'll keep that sideways light spill under review.
Have done a test fitting of a pair of LED units into one indicator unit on the bench, and fortunately the LEDs main throw is forward (they have a lens at the tip), and they sit inside the silvered masked portion at the side.
Still a bit of playing about to do.
Have seen a good few cars with aftermarket LED strips under headlights, and it would be a very straightforward fitting in that gap on the BX. However, I'm not keen on the drastic change in driving appearance it would give the car, so would rather make use of the existing small fittings.
This is what I achieved for the XM a couple of years ago...
While by the letter of the law that wouldn't be legal here, and the UK has its own rules on vehicle lighting, that looks so 'Factory' i bet no one would even notice.
I do recognise your concerns about being seen. Amazingly the BX isn't the worst car I own for light output, and the other one was made in 2013!
